mdbctl traceprop 命令介绍
更新时间: 2025/12/23
在AtomGit上查看源码命令介绍
traceprop <operation type> <object name> <interface name> <property name>
operation type: 必选参数,提供trace/untrace两种模式,代表开始跟踪与停止跟踪 object name: 必选参数,为指定属性接口所属的对象,可以通过lsobj查询组件有哪些对象 interface name: 必选参数,为指定属性所挂的接口,可以通过lsprop查询对象下挂了哪些接口 property name: 必选参数,为指定属性,可以通过lsprop查询对象下的属性
可以通过如下流程获取组件下的接口与属性
-- 通过lsclass直接获取所有类名
% lsclass
Accessor AccountService AssetChange AssetList Authorization BMA BMC Battery Bios BiosUpgradeService BoardNICCard BoardRAS BootError BootOptions BusinessConnector CPU CPUMetrics CPURAS Certificate CertificateLocation CertificateService Chassis ChassisBMC Chip Component ComputerSystem Connector Contact Controller CoolingArea CoolingConfig CoolingFan CoolingPolicy CoolingRequirement Cpld CpuBoard DFT DataAcquisitionService Dft12V0Vlot Dft3V3Vlot Dft5V0Vlot DftBmcCard DftButtonCell DftCD DftChassisCover DftCpld DftDdr3 DftEeprom DftEepromWp DftEth DftFlash DftI2c DftIOTest DftIpmb DftJTAG DftKeyBoard DftLedIntelligence DftLedTube DftLedTubeIntelligence DftLm75 DftLpc DftNCSI DftNandFlash DftNewVideo DftPca9545 DftPca9555 DftPmu DftPowerButton DftPowerSupply DftPysicalLed DftSPI DftUidButton DftUsb DiscreteEvent DiscreteSensor Drive Eeprom EnergyMetric Entity EthGroup Event EventMetrics Events ExpBoard FDMDomain FDMService Fan FanBoard FanType FaultPrediction Firewall FirmwareActive FirmwareInventory FirmwareMatchRules Fru FruCtrl FruCtrlCapabilities FruData Gpio HddBackplane Hisport HostKeyAlgorithm I2c I2cMux InferenceAsync IpmiCore JobService Jobs Jtag JtagOverLocalBus Key KeyService Keys LanSwitch Led LedPolicy LicenseService LldpConfig Lm75 LocalAccountAuthN LogMock LogServices MacaService ManagerAccounts ManagerVersion MdbService Memory MemoryChannel MemoryMetrics MemoryRAS Mock Multihost NCSICapabilities NandFlash NandFlashCtrl NandFlashMock NetworkAdapter NetworkPort NodeLocation ObjectGroup OnePower PCIeCard PCIeDevice PCIeRASCollector Package Pca9545 Pca9555 PcieAddrInfo Pmu PowerAction PowerStrategy Product RMCPCipherSuites Redfish RestrictedPrivileges RiserCard SASPhy SOC SOL SP Scanner SecureBootOptions Sender SensorSelInfo SerialManagement SerialManagementConfig SmBios Smc Sms Smtp Snmp StorageConfig Syslog SystemFirmwareProgress SystemLockDown Temperature ThresholdSensor Time TraceIpmi TrustedSupplyChain UartData Ums UnitConfiguration UpdateMgmt UpdateService Upgrade UsbLocalOMService Watchdog2
-- lsclass [组件]获取类名
% lsclass hwdiscovery
Connector ObjectGroup
-- lsobj <类名>获取对象名
% lsobj Connector
Connector_BCU_1_0101
Connector_CLU_1_0101
Connector_EXU_1_01
-- lsprop <对象名>获取下挂接口与属性
% lsprop Connector_BCU_1_0101
bmc.kepler.Connector
AuxId=""
Bom="14100513"
Buses=["I2c_1","I2c_2","I2c_8","JtagOverLocalBus_1","Hisport_0","Hisport_5","Hisport_6","Hisport_7"]
ChassisId="1"
GroupId=14
GroupPosition="010101"
Id="00000001020302024339"
IdentifyMode=3
LoadStatus=0
ManagerId="1"
Presence=1
SilkText="BCU"
Slot=1
SystemId=1
Type="CPUBoard"
bmc.kepler.Object.Properties
ClassName="Connector"
ObjectIdentifier=[1,"1","1","0101"]
ObjectName="Connector_BCU_1_0101"使用示例
-- 需要traceprop必须要先attach到组件
% attach hwdiscovery
Success
-- 按照方法介绍使用
% traceprop trace Connector_BCU_1_0101 bmc.kepler.Connector LoadStatus
Success
-- 属性变更后会在mdbctl客户端有变更回显
% 2025-02-13 02:05:31.013912, :1.160, /bmc/kepler/Connector/Connector_BCU_1_0101, bmc.kepler.Connector, LoadStatus, 0, 1 Override(set)
2025-02-13 02:05:40.877220, :1.161, /bmc/kepler/Connector/Connector_BCU_1_0101, bmc.kepler.Connector, LoadStatus, 1, 0 Override(unset)
--使用untrace或attach其他组件或者退出mdbctl都会使跟踪中断
% traceprop untrace Connector_BCU_1_0101 bmc.kepler.Connector LoadStatus
Success属性变更回显格式为[属性变更时间],[发起变更服务名或会话id],[对象路径],[接口名],[属性名],[变更旧值],[变更新值],[变更模式(mdbctl的setprop为Override(set))]
注意事项
- mdbctl >= 1.20.12 && libmc4lua >= 1.50.32支持traceprop命令
- libmc4lua >= 1.50.43 支持追踪由mdbctl setprop设置的属性值
- 必须attach组件后才可以使用traceprop命令
- 操作traceprop后,中途attach其他组件或者退出mdbctl会使trace中断
- 最多同时traceprop 5个属性
