This document describes how to configure and create white box packages.
Introduction to White Box Packages
A white box package is essentially an HPM package that provides customization capabilities through firmware updates. The range of customization includes image customization, web page style customization, and configuration customization. The following table lists the supported customization items.
No.Customization CategoryCustomization ItemFileAttribute
1Image customizationBrowse ICOfavicon.ico/
2Image customizationQR codecode1.png/
3Image customizationLogin page backgroundlogin.png/
4Image customizationLogin page iconlogin_logo.png/
5Image customizationModel display on the main pageimg_01.png img_02.png img_03.png/
6Image customizationImage in the upper left corner of the main pageheader_logo.png/
7Style customizationMain page stylestyle_config.jsonpageStyle
8Configuration customizationProduct contact personweb_custom.xmlsysContact
9Configuration customizationDefault security advisoriesweb_custom.xmldBannerContent
10Configuration customizationPreset certificate Common Nameweb_custom.xmlPreSSLSeverCommonName
11Configuration customizationPreset certificate Organization Nameweb_custom.xmlPreSSLSeverOrgName
12Configuration customizationPreconfigured certificate Countryweb_custom.xmlPreSSLSeverCountry
13Configuration customizationOfficial websiteweb_custom.xmlOfficalWeb
14Configuration customizationCopyright informationweb_custom.xmlCopyright
15Configuration customizationTechnical support websiteweb_custom.xmlSupportWeb
16Configuration customizationEmailweb_custom.xmlEmail
17Configuration customizationPhoneweb_custom.xmlPhone
18Configuration customizationIndependent KVMweb_custom.xmlDownloadKVMLink
19Configuration customizationQR code display flag (whether to display)web_custom.xmlDocSupportFlag
20Configuration customizationBMC software nameweb_custom.xmlSoftwareName
21Configuration customizationAlarm and event descriptionweb_custom.xmlCustomAlarmName
22Configuration customizationRedfish OEM nameweb_custom.xmlCustomManufacturer
23Configuration customizationBMC host nameweb_custom.xmlHostName
24Configuration customizationCustomer name (used to make customized features take effect)web_custom.xmlCustomer
White Box Package Customization Method
Creating a Code Repository for Storing Customization Files
Before creating a white box package, prepare the customization files. White box package customization files include the main page style description file, various customized images, configuration file web_custom.xml, and file list configuration filelist.conf.
  • Customized image names must match those in the item customization table above.
  • The main page style supports beautiful, simple, and standard. You need to create a style_config.json file.
The file configuration example is as follows:
  "pageStyle": "beautiful"
Configuring filelist.conf
The filelist.conf file describes white box package configuration items. The following is an example:
[Basic]
Version=2.00
[Filelist]
FileNum=10
[File0]
Path=/data/opt/pme/web/htdocs/theme/custom/img
[File1]
Name=favicon.ico
[File2]
Name=web_custom.xml
Path=/data/opt/pme/web/conf
[File3]
Path=/data/opt/pme/web/custom
[File4]
[File5]
[File6]
[File7]
[File8]
[File9]
Name=style_config.json
  • [Basic]: describes the filelist.conf file version.
  • [Filelist]: describes the number of configuration files.
  • [Filex]: describes configuration file names and file paths.
The value of FileNum must match the actual number of File entries configured below. File names and file paths are fixed. You can customize them as required.
Configuring web_custom.xml
The web_custom.xml file contains attribute configurations. The following is an example:
xml
<?xml version="1.0" encoding="UTF-8"?>
<!-- Description: Currently official website, copyright information, independent KVM download link information, and document QR code display flags are used in the web page. -->
<CUSTOM_CONFIG>
    <!-- System contact (Example: VALUE="https://openubmc.com") -->
    <SysContact VALUE="CustomSysContact" />
    <!-- Preset SSL certificate information. When the issuer information of the currently installed SSL certificate matches the preset information, the certificate is considered a preset certificate, and the web page will prompt the user to install a new certificate. -->
    <PreSSLSeverCommonName VALUE="CustomCommonName"/>
    <PreSSLSeverOrgName VALUE="CustomOrgName"/>
    <PreSSLSeverCountry VALUE="Country"/>
    <!-- Official website -->
    <OfficalWeb VALUE="CustomOfficalWeb"/>
    <!-- Copyright -->
    <Copyright VALUE="CustomCopyright"/>
    <!-- Technical support website -->
    <SupportWeb VALUE="CustomSupportWeb"/>
    <!-- Email -->
    <Email VALUE="CustomEmail"/>
    <!-- Phone -->
    <Phone VALUE="CustomPhone"/>
    <!-- Independent KVM client download link -->
    <DownloadKVMLink VALUE="CustomDownloadKVMLink"/>
    <!-- Whether to display the QR code. (Example: VALUE="1", where "0" or "1" are valid values. Other values default to "0", indicating that the OR code is not displayed.) -->
    <DocSupportFlag VALUE="CustomDocSupportFlag"/>
    <!-- Software name, used for customizing the BMC name in logs and the CLP prompt. -->
    <SoftwareName VALUE="openUBMC"/>
    <!-- Host name -->
    <HostName VALUE="CustomHostName"/>
    <!-- Security advisories -->
    <dBannerContent VALUE="CustomdBannerContent"/>
    <!-- Customer name -->
    <Customer VALUE="CustomerName"/>
</CUSTOM_CONFIG>
You can select appropriate customization items to put into web_custom.xml as required. Replace VALUE content with your customized content. You can delete unnecessary customization items.
Configuring manifest.yml for the Corresponding Product in the manifest Repository
After preparing the white box package customization files, start the build and packaging phase. The configuration steps are as follows:
(1) Determine the build code, such as WBD. (2) Determine the package name package_name. (3) Determine the build type. (4) Configure settings related to the white box package.
Build example:
yml
manufacture:
    # Build code.
    WBD:
        # package_name is the storage path and name of the white box package.
        package_name: wbd/wbd_output.zip
        # Build type. See bingo build types for optional values.
        build_type: release
        # White box package-related configuration.
        wbd_hpms:
            # repo is the repository address where white box package customization files are stored. Use the HTTPS download address.
            - repo: https://test.git
              # tag is the branch tag number where customization files are stored.
              tag: 0.0.0
              files:
                # path is the storage path for white box package customization files. The dst path cannot be modified and must follow the format "wbd_up_file/filename" as shown in the following example.
                - file: {path}/favicon.ico
                dst: wbd_up_file/favicon.ico
                - file: {path}/login_logo.png
                dst: wbd_up_file/login_logo.png
                - file: {path}/header_logo.png
                dst: wbd_up_file/header_logo.png
                - file: {path}/filelist.conf
                dst: wbd_up_file/filelist.conf
                - file: {path}/web_custom.xml
                dst: wbd_up_file/web_custom.xml
                # The following files are required for creating white box packages. Their paths are fixed and cannot be deleted.
                - file: /usr/share/bmcgo/wbd-packet/beforeaction.sh
                - file: /usr/share/bmcgo/wbd-packet/afteraction.sh
                dst: afteraction.sh
                - file: /usr/share/bmcgo/wbd-packet/CfgFileList.conf
                - file: /usr/share/bmcgo/wbd-packet/firstboot.sh
                - file: /usr/share/bmcgo/wbd-packet/hpm_wbd.config
                - file: /usr/share/bmcgo/wbd-packet/packetwbd.sh
                - file: /usr/share/bmcgo/wbd-packet/update.cfg
        # dst is the name of the final white box package created.
        files:
          - file: ${work_out}/wbd_hpm1.hpm
            dst: WBD-image.hpm
            verify:
              - pss
Note: The number of customization files in files must match the number of files in filelist.conf. Otherwise, the white box package upgrade will fail.
Running the White Box Build Command in the build Directory of the manifest Repository
Go to the manifest/build directory and run the following command:
bingo publish -z WBD -b openUBMC, where the -z option is the white box package build code and the -b option is the model.
The package will be created at manifest/output/packet/wbd/wbd_output.zip.
Upgrading the White Box Package
Go to the openUBMC home page, navigate to Firmware Upgrade -> Firmware Update -> Upgrade File. If the Customer field is configured in the white box package, it will automatically restart to take effect after the update completes.
Clear Branding Package Creation Method
After customizing a white box package, if you need to restore the original configuration, you need to update with a clear branding package. A clear branding package is also a white box package, but the configuration in it is the default configuration. You need to create a white box package with the default configuration.
  1. For configuration customizations, modify the customization items in web_custom.xml to the desired default values.
  2. For style customizations, set the style_config.json file to an empty object.
  3. For image customizations, configure filelist.conf, change the original Name to CLEAR_ALL, and then create an empty file named CLEAR_ALL. Note that when configuring the white box package in manifest, you also need to add the CLEAR_ALL file configuration.
filelist.conf example:
# For configurations that need to be restored to default, change Name to CLEAR_ALL.
[Basic]
Version=2.02
[Filelist]
FileNum=9
[File0]
[File1]
Name=favicon.ico
[File2]
Name=web_custom.xml
[File3]
Name=CLEAR_ALL
[File4]
Name=CLEAR_ALL
[File5]
Name=CLEAR_ALL
[File6]
Name=CLEAR_ALL
[File7]
[File8]
