- Each component of openUBMC has its own build code and repository. The
manifestrepository integrates all code involved for the build. A main component is started to parse dependencies using the built-in resolution logic of Conan, and then concurrent build is performed based on the dependency logic. - The
manifestrepository is used as the main entry point for the build, and all build capabilities are integrated into thebingocommand for convenient use.
Build Command Overview
- The following is the help document of
bingo. This help document in themanifestrepository path (product path) is different from that in the component repository path. During product build, you only need to focus on the behavior in themanifestrepository.
# Run the following command in the manifest path:
[04:51:58 root(1110):/home/workspace/codehome/manifest]# bingo --help
Integrated commands
build Build the package.
publish Build the version release package. Use -sc to specify the ToSupportE code and -z to specify the ToGPD production equipment code.
qemu Create a simulation environment and run the built product package.
fetch Pull full code based on component versions specified by parameters.
Misc commands
help Get command help.
Enter "bingo <command>" -h to get subcommand help.
[04:52:01 root(1110):/home/workspace/codehome/manifest]#- The returned information shows the commands available. Only one of the commands is used to build products and release packages. Currently, the
buildcommand has the same effect aspublish.
[04:52:01 root(1110):/home/workspace/codehome/manifest]# bingo build --help
Building the BMC.
options:
-h, --help show this help message and exit
-b BOARD_NAME, --board_name BOARD_NAME
Board package. The value can be a directory name in build/product/.../.
-bt BUILD_TYPE, --build_type BUILD_TYPE
Build type. The options are debug (debug package), release (official release package), and dt (developer test package).
--stage STAGE Package type. The options are dev (debugging package), rc (pre-release package), and stable (release package).
Default value: dev
--verbose Enables detailed log printing for Conan build.
-ucc, --update_conan_cache
Fully update the local Conan cache.
-r REMOTE, --remote REMOTE
Alias of the Conan repository. Check the configured Conan repository in the Conan remote list.
Default value: openUBMC_dev
-sc SUPPORTE_CODE, --supporte_code SUPPORTE_CODE
SupportE code to be released. For details about the options, see manifest.yml/tosupporte of the board.
Default value: default
-q, --enable_qemu Enables QEMU packaging.
-qi, --qemu_in Enables QEMU and automatically starts the QEMU environment.
-as, --asan Enables the address sanitizer.
-v VERSION, --version VERSION
Build version number. If this parameter is not specified, the version number is read from manifest.yml.
-t TARGET, --target TARGET
Build target. For details, see the build/target directory. The following targets are supported:
personal
publish
[04:59:33 root(1110):/home/workspace/codehome/manifest]#1. Product Package Build Commands
Building an HPM package directly
Start building an HPM package. Review the help information above to understand its specific meaning. After the command finishes, the built HPM package can be found in the
outputdirectory under themanifestdirectory.shell# Enter the integrated build environment. cd manifest # -t personal: Build target. Personal build refers to the HPM package. # -b openUBMC: Board name. You can view the supported boards in the help document. # -bt release: Build type, which is a official release package. # --stage rc: Package type, which is a pre-release package. bingo build -t personal -b openUBMC -bt release --stage rcThe following lists the files in the generated file directory.
rootfs_openUBMC.hpmis the product package.shell[05:22:48 root(1110):/home/workspace/codehome/manifest/output]# ls -la total 70172 -rw-r--r-- 1 root root 1349 Mar 12 17:22 openubmc.perf -rw-r--r-- 1 root root 54813 Mar 12 17:22 package.lock drwxr-xr-x 5 root root 4096 Mar 7 14:32 packet -rw-r--r-- 1 root root 0 Mar 12 17:20 prof.perf.lock -rw-r--r-- 2 root root 70144173 Mar 12 17:22 rootfs_openUBMC.hpm [05:23:04 root(1110):/home/workspace/codehome/manifest/output]#
Scenario for integrating released components: After a component is released, its version needs to be integrated into the product package. The modification method is as follows:
Add the new component to its corresponding type category within the
subsysdirectory. Becausesubsysseparatesrcandstabletypes, you must update both directories simultaneously. The following example demonstrates thercversion. For thestableversion, replace the suffix withstable.yaml# yaml-language-server: $schema=../../schema/subsys.rc.schema.json dependencies: - conan: "rackmount/1.20.97@openUBMC.release/rc" - conan: "Kunpeng/1.10.2@openUBMC.release/rc"Configure the added component in the
manifest.ymlfile. Newly introduced components must be configured with dependencies in the product directory. Otherwise, the components will not be integrated into the product package. In thedependenciesfield, each configured component is integrated. Do not fill in the version number. If the version number is included, multiple files will need to be modified when the component version is updated.yamldependencies: - conan: "huawei_secure_c" - conan: "kmc" - conan: "Signature_Verify_CBB_Library" - conan: "sqlite3" - conan: "openssh"
2. Release Package Build Commands
Release package build commands are slightly different from the preceding commands, as shown in the following:
shell# Enter the integrated build environment. cd manifest # -t publish: Build target, which is a release package. # -sc default: Release package code, which can be found in the tosupporte field in the manifest.yml file. # -b openUBMC: Board name. You can view the supported boards in the help document. # -bt release: Build type, which is a official release package. # --stage stable: Package type, which is a release package. bingo build -t publish -sc default -b openUBMC -bt release --stage stableAfter the execution is complete, files are generated in the
outputdirectory. The following shows the tree structure of theoutputdirectory (for reference only).shell[07:05:30 root(1110):/home/workspace/codehome/manifest/output]# tree . |-- openUBMC.perf |-- package.lock |-- packet | |-- openUBMC | | |-- openUBMC-CMT_1.00.00.00.zip | `-- inner | |-- release | | |-- package_openUBMC.lock |-- prof.perf.lock `-- rootfs_openUBMC.hpm 4 directories, 6 files [07:05:31 root(1110):/home/workspace/codehome/manifest/output]#
