NIC Adaptation Guide
更新时间: 2025/07/01
This section describes how to adapt a NIC on openUBMC.
NIC Introduction
The network interface controller (NIC), also known as a network adapter, network interface card, or LAN adapter, is the hardware that enables the server to communicate over a network.
NICs are a key part of modern infrastructure. As technology advances, many different types of NICs have been developed. In out-of-band management, supporting diverse NICs has been a challenge in BMC technology. Based on the adapted NICs, openUBMC has formed a unified management framework to standardize management.
NIC Adaptation Process
Like other components, each NIC has a CSR file.
To simplify CSR configuration, you are advised to use BMC Studio for adaptation.
The Role of CSR in NIC Adaptation
The CSR file tells the BMC how to identify, manage, and monitor a NIC. Just like a driver is required when installing new hardware on a computer, this configuration file tells the BMC:
  • Regular information such as the name and model of the NIC
  • Out-of-band protocols supported by the NIC
  • How to monitor working status of the NIC
  • Issues to report
  • The sensor for NIC management
Information Contained in CSR
  • Device identification: the static information of the NIC, which helps the BMC to identify installed NICs
  • Status monitoring: the hardware topology information of the NIC for real-time monitoring, including temperature of the NIC, network port, and optical module
  • Fault reporting: sensor and event configuration of the NIC, specifying under which conditions the NIC's status triggers event reporting
  • Speed adjustment policy: the NIC's speed adjustment configuration, guiding the BMC's overall speed adjustment strategy
Step 1: Learning About the NIC to Be Configured
  • Check the NIC model (usually marked on the NIC).
  • Confirm the NIC type (PCIe, OCP, or onboard).
  • Record the NIC's basic information (such as the four-tuple information).
  • The thermal design document, which guides the speed adjustment policy
  • The sensors and event design
Step 2: Configuring Basic Information for the NIC
Configure basic information to ensure that the NIC can be loaded.
  • Configure the correct file name of the NIC using the BOM and four-tuple information.
  • Enter the NIC name and model.
  • Select the correct NIC type.
  • Enter the vendor ID and device ID.
PCIe Device Object (PCIeDevice_1)
Define the basic attributes and types of the PCIe device.
  • Device name
  • Function type
  • Device type
  • Slot type
    "PCIeDevice_1": {
        "DeviceName": "PCIe Card $ (device model)",
        "FunctionClass": 2,  // Function type
        "PCIeDeviceType": "MultiFunction",  // Device type
        "SlotType": "FullLength",  // Slot type
        "FunctionProtocol": "PCIe",  // Protocol type
        "FunctionType": "Physical"  // Function type
NIC Object (PCIeCard_1)
Define the basic information and attributes of the NIC.
  • Name
  • Description
  • Vendor ID
  • Device ID
  • Manufacturer information
    "PCIeCard_1": {
        "Name": "Name",
        "Description": "Description",
        "VendorID": "VendorID",
        "DeviceID": "DeviceID",
        "Manufacturer": "Manufacturer",
        "PartNumber": "PartNumber",
        "Model": "Model",
        "FirmwareVersion": "FirmwareVersion",
        "SerialNumber": "SerialNumber"
Network Adapter Object (NetworkAdapter_1)
Define the functions and features of the network adapter.
  • Name
  • Description
  • Number of ports
  • Supported features
    "NetworkAdapter_1": {
        "Name": "Name",
        "NetworkPortCount": "NetworkPortCount",
        "SupportedMctp": true,  //Whether MCTP is supported
        "SupportedLLDP": true,  // Whether LLDP is supported
        "HotPluggable": false,  // Whether hot swap is supported
        "LinkWidth": "LinkWidth",
        "LinkSpeed": "LinkSpeed"
NIC Objects
Different objects are used for different types of NICs.
  1. Standard PCIe NIC (BoardPCIeCard_1)
    • Applicable to independent PCIe NICs
  2. OCP NIC (OCPCard_1)
    • Applicable to OCP NICs
  3. Onboard NIC (BoardNICCard_1)
    • Applicable to the NIC integrated on the mainboard
The standard PCIe NIC object (BoardPCIeCard_1) is applicable to the standard PCIe NIC.
  • Slot information
  • Link capability
  • Board type
  • FRU information
    "BoardPCIeCard_1": {
        "Slot": 1,
        "UID": "N/A",
        "Name": "Name",
        "Type": "PCIeCard",
        "BoardType": "BoardPCIeCard",
        "Number": 1,
        "DeviceName": "<=/PCIeDevice_1.DeviceName",
        "Position": "<=/PCIeDevice_1.Position",
        "LinkWidthCapability": "<=/NetworkAdapter_1.LinkWidthCapability",
        "LinkSpeedCapability": "<=/NetworkAdapter_1.LinkSpeedCapability",
        "LinkWidth": "<=/NetworkAdapter_1.LinkWidth",
        "LinkSpeed": "<=/NetworkAdapter_1.LinkSpeed",
        "BoardNodeId": "<=/PCIeDevice_1.DeviceName",
        "FruID": "<=/Fru_PCIeCard.FruId"
The OCP NIC object (OCPCard_1) is used for the OCP NIC.
  • Specific OCP attributes
  • Link capability
  • Board type
  • FRU information
    "OCPCard_1": {
        "Slot": 1,
        "UID": "N/A",
        "Name": "Name",
        "Type": "OCPCard",
        "BoardType": "OCPCard",
        "Number": 1,
The onboard NIC object (BoardNICCard_1) is used for the onboard NIC.
  • Specific onboard attributes
  • Link capability
  • Board type
  • FRU information
    "BoardNICCard_1": {
        "Slot": 1,
        "UID": "N/A",
        "Name": "Name",
        "Type": "NICCard",
        "BoardType": "BoardNICCard",
        "Number": 1,
Step 3: Configuring Basic Network Port Information
Network Port Object (NetworkPort_X)
Define the network port attributes and capabilities.
  • Port ID
  • Medium type
  • Link capability
    "NetworkPort_0": {
        "@Parent": "NetworkAdapter_1",
        "SystemID": 1,
        "PortID": 0,
        "NetDevFuncType": "NetDevFuncType",
        "MediumType": "FiberOptic",  //Medium type
        "SupportedLinkCapability": "SupportedLinkCapability"
Optical Module Object (OpticalModule_X)
Define the attributes and monitoring parameters of optical modules (for NICs that support optical modules).
  • Channel number
  • Temperature
  • Power supply status
  • Threshold
    "OpticalModule_0": {
        "@Parent": "NetworkPort_0",
        "ChannelNum": 1,
        "TemperatureCelsius": 0,
        "PowerState": 0,
        "IsSupportedType": 0,
        "Temp_UpperThresholdCritical": 125
Step 4: Configuring Monitoring Parameters
For configuration, refer to Sensor Customization and Development. The following example focuses solely on the monitoring configuration of NIC sensors.
  • Set the temperature monitoring threshold for alarm reporting or speed adjustment.
  • Configure voltage and power monitoring for alarms or sensors.
  • Set status monitoring parameters.
Threshold Sensor Object (ThresholdSensor)
  • Applicable scenarios:
    • Temperature monitoring
    • Voltage monitoring
    • Power monitoring
  • Key attributes:
    • Threshold settings
    • Hysteresis value
    • Linearization parameters
    "ThresholdSensor_Temp": {
        "AssertMask": 128,
        "DeassertMask": 28800,
        "ReadingMask": 2056,
        "Linearization": 0,
        "M": 100,
        "RBExp": 224,
        "UpperNoncritical": 105,
        "PositiveHysteresis": 2,
        "NegativeHysteresis": 2
    "ThresholdSensor_Voltage": {
        "AssertMask": 128,
        "Linearization": 0,
        "M": 100,
        "RBExp": 224,
        "LowerNoncritical": 3.0,
        "UpperNoncritical": 3.6,
        "PositiveHysteresis": 0.1,
        "NegativeHysteresis": 0.1
    "ThresholdSensor_Power": {
        "AssertMask": 128,
        "Linearization": 0,
        "M": 100,
        "RBExp": 224,
        "UpperNoncritical": 25,
        "PositiveHysteresis": 1,
        "NegativeHysteresis": 1
Discrete Sensor Object (DiscreteSensor)
Used to monitor the discrete status
    • Device installation status
    • Fault status
  • Key attributes:
    • Status mask
    • Type definition
    "DiscreteSensor_Presence": {
        "AssertMask": 1,
        "DeassertMask": 2,
        "ReadingMask": 3,
        "Type": 0
    "DiscreteSensor_PowerState": {
        "AssertMask": 4,
        "DeassertMask": 8,
        "ReadingMask": 12,
        "Type": 0
    "DiscreteSensor_FaultState": {
        "AssertMask": 16,
        "DeassertMask": 32,
        "ReadingMask": 48,
        "Type": 0
Cooling Control Object (CoolingRequirement_X)
Define the cooling control parameters.
  • Target temperature
  • Maximum allowed temperature
    "CoolingRequirement_1_50": {
        "MonitoringStatus": "MonitoringStatus",
        "TargetTemperatureCelsius": 90,
        "MaxAllowedTemperatureCelsius": 102
Step 5: Configuring the Management Feature
  • Configure fault alarm conditions.
  • Set the code of the LED indicator.
  • Define alarm levels.
For fine-grained alarm development, refer to Event Customization. The following example focuses solely on NIC alarms.
Basic Event Object
Define basic event monitoring.
    "Event_PCIeBandWidth": {
        "EventKeyId": "PCIeCard.PCIeCardBandWidthDecreased",
        "xxx": "xxxx"
    "Event_PCIeLinkSpeed": {
        "EventKeyId": "PCIeCard.PCIeCardLinkSpeedReduced",
        "xxx": "xxxx"
    "Event_PCIeCardUCE": {
        "EventKeyId": "PCIeCard.PCIeCardUncorrectableErr",
        "xxx": "xxxx"
Temperature Events
    "Event_OverTemp": {
        "EventKeyId": "PCIeCard.PCIeCardOverTemp",
        "xxx": "xxxx"
    "Event_TempFail": {
        "EventKeyId": "PcieCard.PCIeCardTempFail",
        "xxx": "xxxx"
    "Event_TempSensorFail": {
        "EventKeyId": "PcieCard.PCIeCardTempSensorFail",
        "xxx": "xxxx"
Power Supply Events
    "Event_PowerFail": {
        "EventKeyId": "PCIeCard.PCIeCardPowerFail",
        "xxx": "xxxx"
    "Event_VoltageAlarm": {
        "EventKeyId": "PCIeCard.PCIeCardVoltageAlarm",
        "xxx": "xxxx"
    "Event_PowerOverload": {
        "EventKeyId": "PCIeCard.PCIeCardPowerOverload",
        "xxx": "xxxx"
Port Events
    "Event_Port1LinkDown": {
        "EventKeyId": "Port.PortDisconnected",
        "xxx": "xxxx"
    "Event_OM1PowerAlarm": {
        "EventKeyId": "Port.PortOpticalModulePowerAlarm",
        "xxx": "xxxx"
    "Event_OM1SpeedMatch": {
        "EventKeyId": "Port.PortOpticalModuleSpeedMismatch",
        "xxx": "xxxx"
    "Event_Port1BWUsageMntr": {
        "EventKeyId": "NICCard.SystemNetworkBandwidthUsageHigh",
        "xxx": "xxxx"
Device Status Events
    "Event_DevicePresence": {
        "EventKeyId": "PCIeCard.PCIeCardPresence",
        "xxx": "xxxx"
    "Event_PowerState": {
        "EventKeyId": "PCIeCard.PCIeCardPowerState",
        "xxx": "xxxx"
    "Event_FaultState": {
        "EventKeyId": "PCIeCard.PCIeCardFaultState",
        "xxx": "xxxx"
FRU Object (Fru_PCIeCard)
  • FRU ID
  • Name
  • PCB ID
    "Fru_PCIeCard": {
        "PcbId": "PCB ID",
        "FruId": 1,
        "FruName": "FruName",
        "ConnectorGroupId": "ConnectorGroupId",
        "BoardId": 255
Step 6: Configuring Out-of-Band Information Obtaining
The NetworkAdapter object has a Model attribute, which is used with the community component network_adapter to load and specify a protocol to obtain the out-of-band NIC information.
Chip Object (Chip_X)
Define chip access parameters.
  • Address
  • Timeout duration
    "Chip_Hi1822": {
        "OffsetWidth": 0,
        "AddrWidth": 1,
        "Address": 232,
        "WriteTmout": 100,
        "ReadTmout": 100
Management Bus Object
Define the bus for a chip and ensures that the chip is accessible.
  • Bus type
  • Channel
                "I2cMux_Chan"
