Hardware Proxy Access Control Methods
更新时间: 2025/10/15
在AtomGit上查看源码Hardware Proxy Access Control Method
1. Overview
The hardware proxy provides access control capabilities for hardware devices and links. In specific scenarios (such as component upgrade and maintenance), access can be temporarily disabled or restored to prevent errors caused by unstable status, such as dirty data reading and operation failures.
2. Component Access Control
2.1 Interface Definition
Method: SetAccessibilityPath: /bmc/kepler/Chip/DeviceType/DeviceInstanceParameters:
Status(Boolean):true: Enables component access (DisableDurationis ignored).false: Disables component access (requiresDisableDurationto specify the duration).
DisableDuration(integer, unit: seconds):- Range:
1 ≤ DisableDuration ≤ 1800. An error is returned if the value is out of range. - Takes effect only when
Status=false. Access is automatically restored after the duration ends.
- Range:
2.2 Operation Logic
- Disabling access:
- All operations (scanning, block read, block write, bit read, bit write) are blocked during the disabling period.
- Access can be restored early by calling
SetAccessibility(Status=true)again.
- Automatic restoration: The component access status is automatically reset to enabled after the disabling duration ends.
2.3 Examples
# Enable component access.
busctl --user call bmc.kepler.hwproxy /bmc/kepler/Chip/Eeprom/Eeprom_3_10_01 bmc.kepler.Chip SetAccessibility a{ss}bq 0 true 1
# Disable component access for 60 seconds.
busctl --user call bmc.kepler.hwproxy /bmc/kepler/Chip/Eeprom/Eeprom_3_10_01 bmc.kepler.Chip SetAccessibility a{ss}bq 0 false 603. Link (Bus) Access Control
3.1 Interface Definition
Method: SetAccessibilityPath: /bmc/kepler/Bus/BusType/BusInstanceParameters:
Status(Boolean):true: Enables link access.false: Disables link access (requiresDisableDurationto specify the duration).
DisableDuration(integer, unit: seconds):- Follows the same rules as the component access control parameter (range: 1s to 1800s).
3.2 Key Features
- Status priority:
- When a link is disabled, you cannot set the access status for components under that link.
- Timeout restoration:
- Access is automatically restored after the duration ends.
- You can query the current link status using the
AccessEnabledinterface. - The
Timeoutparameter displays the remaining restoration time (refreshed every 10s).
3.3 Examples
# Disable I2C bus access (for 30 seconds).
busctl --user call bmc.kepler.hwproxy /bmc/kepler/Bus/I2c/I2c_1 bmc.kepler.Bus SetAccessibility a{ss}bq 0 false 30
# Restore I2C bus access.
busctl --user call bmc.kepler.hwproxy /bmc/kepler/Bus/I2c/I2c_1 bmc.kepler.Bus SetAccessibility a{ss}bq 0 true 14. Precautions
- Parameter validation:
- The interface returns an error if
DisableDurationis outside the range of 1s to 1800s.
- Status conflicts:
- When a link is disabled, the access control interfaces for all components under it cannot be called.
- Timeout mechanism:
- The system automatically removes the restriction after the duration ends, requiring no additional operation.
- Command syntax:
a{ss}bqin thebusctlcommand is a fixed parameter type declaration and must remain unchanged.
Note: You are advised to use link-level control to override component-level configurations for access restrictions with a higher priority.
